MustangForums.com
MustangForums.com (https://mustangforums.com/forum/index.php)
-   4.6L (1996-2004 Modular) Mustang (https://mustangforums.com/forum/4-6l-1996-2004-modular-mustang-7/)
-   -   Eibach Pro Kit Rear Pinion Snubber? (https://mustangforums.com/forum/4-6l-1996-2004-modular-mustang/48856-eibach-pro-kit-rear-pinion-snubber.html)
josh_0351 05-22-2005 02:01 PM
Do you really need to install the stock replacement rear rubber pinion snubbed that comes with Eibach Pro Kit lowering springs?
jishead 05-30-2005 04:24 AM
RE: Eibach Pro Kit Rear Pinion Snubber?
I have the sportlines which are lower. I did not install mine for months after. I heard sounds that I did not like so later I installed the snubber and it did not seem to make any diff. The noises that I heard ended up being the big fat Magnaflow pipes banging the sway bar and fuel tank shell. I adjusted everything and no more noises. I don't think that the snubber would make much diff especially on the ProKit which is higher that many lowering springs.
