Polished Throttle Bodie
RE: Polished Throttle Bodie
I agree with Emann0007, don't waste your time on something that will net you 1/2HP gain at best. Get a new throttle body and plenum. Check out this site for some good info on the subject:
http://www.accufabracing.com/technical_faq.htm
If I am not mistaken, the Accufab products are basically polished anyway. Good quality product. Looks great too with it chromed effect finish. Also, at the same time, if you want a cheap CAI, just add a K&N filter and remove your air silencer. Basically the same exact thing. I did it to mine and don't hear any of the whine that so many people talk about. No sound at all. Then again I am running Magnaflow's in a convertible so perhaps I just can't hear it.....what.....what.....speak up!
Well if you have your heart set on NOT buying a plenum and TB new then you could try and find one used. The $4xx Accufab TB/Plenum will get you like 7HP. Others will get you a tiny bit less. If you are trying to be cheap like me then you can buy an OEM TB/Plenum used from E-bay like I did maybe $30. I am porting and polishing the !@#$ out of it. Half-shaft the butterfly shaft, bevel, port, polish, de-hump, de-burr. It's a probject and I know it won't get me much HP. I'd be very lucky to get 5HP. It's just a cheap project assuming that you already have a nice hi-speed dremmel etc. Sounds like you have the laborer lined out. To answer your question, I agree that you'd be lucky to get 2HP from a fully worked OEM TB only.
