Anyone know what this wire/tube/hose is?
The douche at the muffler shop decided to carelessly saw off my stock exhaust and decided to almost cut off this tube or something and I was wondering if you guys know what it is because I might want to replace it if it's a cheap fix..
It's that thin black wire/hose thingy right above the silver scratches on my chassis. It seems to be connected to a much thicker hose... is it my brakelines or something?
Thanks,
Brandon
Thanks,
Brandon
Well if there is really fluid running through that hose then no he didn't cut it clean through yet because I haven't had any fluid leakage of brake problems but he did cut through the outside of the hose... maybe theres a thin wall still holding the fluids in
You can see the part pointed out where that part of the hose is like "shaved".
Lesson to learn here: While this is not that bad, unless it's a TOP notch shop, do everything yourself by all means because 99% of places will just **** **** up
I mean this is a stupid problem to have.. he used a reciprocating saw with like a 4-5inch blade and he can't even cut my stock exhaut pipe off cleanly and my car was even lifted by a shoplift. I just hate stupid **** happening
