seized caliper sliding pin
the pin is seized up and rusted away pretty much...anyone have a trick to getting this pin out? i put locking pliers on it and then put it at and angle and beat it down with a hammer and all i did was round off the pin some more...its chewed up horribly bad, tried beating it out for an hour with no luck...dont wanna buy a caliper because thats $$....anyone have a trick for this?
yea i tried...only let it sit for 30mins though....im gonna let it sit over night and try...you dont understand how rusted in there the pin is though....its so bad that the boot was rock solid and i had to peel it away and now the pin is like half the diameter it should be because of all the rust that fell out of the boot
yea its off the car, im replacing spider gears in my rear end so i had to pull the brakes off, otherwise i would have never even found it because i never noticed it while driving
Exact same thing happened to me on both rear caliper mounts. It takes a lot of heat from and penetrating oil to get it out. I used an oxy-acetylene torch and ended up getting a small hole in the bracket because it takes a ton of heat to break it loose. Put it in a vice, use a hammer and it will come out.
I used some vice grips, with a really good bite, and hit the vice grips in the jaws with an air hammer.
But if you dont have air tools, a bigger pair of vice grips and a torch are goin to have to do it..
