possible clogged cat???
hey guys new member here. I've been a member of allfordmustangs for awhile and decided to expand my horizons lol.
ok now for the problem. i have a 98 gt that seems to have a severe missfire. Car has a low rpm miss runs ok from 1500-2500 rpms then around 3000 starts to missfire horribly. well atleast i thought i was a missfire, but it doesn't through any codes. it feels like one full bank of cylinders completely shuts down. I've done everything to find this allusive problem. first changed coils and plug wires fixed the problem for 2 days car ran perfect. then like somebody flipped a switch problem came back worse than before. so i checked the fuel pump and pressure everythings fine there. cleaned maf, checked for vacuum leak cars sealed up perfectly, egr seemed ok took the vacuum hose of it went for a drive no different. took the car to my local shop to see if they could find problem no idea. had them clean the injectors and perform some other tests nothing. i've run out of things to check. so now i'm about to check my cats (i have 2/ slp catted x-pipe only 1 yr old) hopefully this cures the problem because if it doesn't i don't have any more ideas
hey thanks for your input guys.
ya i removed each cat seperately and went for a drive after each time trying to isolate the cat. but there was no change when i did this. so after the test i thought i would check the ignition out so i went and bout a timming light. checked each wire out to see what the spark looked like. jesus some wires did some crazy things. i tested them all on idle then again while running. some had a constant spark, while others had mostly constant spark but with some blips. a couple wires didn't seem to have spark for a period of time then start up again. i have 9mm wires so would this effect the timing at all. meaning are the wires to thick for the timing light to pick up the spark?
09-24-2015 09:18 PM
JDWalton
09-24-2015 08:47 PM
trashxtrash
09-20-2015 10:49 PM
