Need help with msd window switch asap
I have a new msd window switch and i have tried everyting i can try to get it to work what i have is the red power wire on the load side of the wot switch so that when i go wot it will activate the window switch i have the ground with all my other grounds and the yellow wire going to my nitrous relay ground that i cut and now it has to ground through the window switch when it hits the desired level. and the white wire is going to the neg coil wire that is closes to the battery it is green with a strip i think. what is going on if i take the unit out nitrous works fine. Thanks
just got off phone with msd and they said that i needed to order a part that would go over the main power wire for the coil on either side and then set it up to run on 4cly and then it would read the signal right now it is just not set up to read a single cyl. wish i would have known that when i bought it.
