knocking clutch or tranny? *with vid
So im getting a pretty crazy knocking sound coming from either my clutch or tranny.It started while driving yesterday.I downshifted to 2nd gear because i was coming around a corner slowly and as soon as i let the clutch out it began.
The sound is very loud and sounds a lot like a knocking engine but the sound goes away as soon as i push in the clutch..Like goes away 100% which leads me to believe it has to be in either the clutch/tranny.
The car still moves just fine which leads me to believe its not the transmission.Im not positive but i would assume if the tranny was broken enough to be making a sound like this it wouldn't still be working properly.The clutch is a Ford Racing king cobra installed about 5,000 miles ago and has been working great since install.
Im really confused on what could be causing the noise. I plan on pulling the tranny this week in hopes that its just a broken spring or something like that on the clutch.But if i dont visually see anything broken on the clutch/pressure plate im really going to be lost.
BTW..The car has never seen the track. Never been on slicks or drag radials.Ive never done any crazy 5k clutch drops or anything like that.The worst beating the car ever sees is a burnout/donut or an easy run through the gears.I have had this car for 3 years and have put almost 50k miles on it and aside from a noisy t/o bearing and one squeeking idler pulley this is the only thing to ever break.
video of the sound http://www.youtube.com/watch?v=WVt0wAOiYiA
Anybody ever have a similar problem?
It's difficult to pin point, but you should jack the car up on the drivers side just enough for you to get under the car to better find the problem. It doesn't sound good and i hope it's not your engine. When you downshifted to 2nd, what gear did you down shift from and has fast were you going.
I dont know how mechanically inclined you are or how willing you are to take things apart but I would get the car on jack stands and drop the tyranny. Take a peek and see how bad it is. If you get in over your head or to a point where you don't feel comfortable working anymore you can always call AAA and have the cat towed to a shop.
My guess is its a destroyed throwout bearing. Or a broken clutch disk but that is less likely if you baby the car.
Im pretty mechanically inclined.Ive done every mod or repair to the car so far.I am the one that installed the king cobra clutch about 5000 miles ago. i do plan to take the tranny out but if i take it apart and its not the clutch or pressure plate im not gonna know where to go from there and ill have a torn apart car.
i bet its just a busted clutch..how do you treat her for the most part? edit:nvm the question, just didnt read the last paragraph before looking at the video..
use a stethoscope to listen to exactly where the noise is coming from. my friend had this happen to his PI swapped 98 gt and i found it was coming from inside the belhousing. turned out he had a cracked flywheel chattering. it could be a multiple of things. anywhere from a loose flywheel or clutch. no pilot bearing, etc. it just all depends. its hard to tell without actually being there.
