FT shocks on 96GT Conv, how hard to change?
its is easy. but once you have the strut and spring assembly out. your going to need a spring compressor to install the new struts. You might be able to take it to a idependent shop and have them swap in the new struts for a few bucks.
For the original poster, it's very simple to do. Shouldn't take more than an hour per side, and that's with no prior experience.
I have no idea why i posted that i was thinking 05 and up suspension.
It is a straight forward swap. just make sure you support the lower control arm before you unbolt anything. this is to keep the tension on the spring. And you should be good to go.
