Procharger D1-SC Questions
Hey guys,
I recently purchased a Procharger D1-SC used. I'd just like to make sure the supporting mods are the right thing. I'm looking to be around 400-410 rwhp. My current mods that are compatable with the s/c are (o/r h midpipe, flows, sct, 3.73s, 75mm tb, plenum, springs...i think thats it)
What I have:
-D1-SC Headunit
-3 Core Intercooler
-Piping/Filter
-BOV
-3.8,3.6 Pulley
What I think I should get:
-SVT Focus Fuel Pump
-42lb Injectors
-90mm Lightning MAF or SCT Big Air MAF
-Different Plugs
-New Tune (have Brenspeed 93 tune on XCal3 now)
-Anderson Power Pipe
Do these look okay?
What I have:
-D1-SC Headunit
-3 Core Intercooler
-Piping/Filter
-BOV
-3.8,3.6 Pulley
-42lb Injectors
-Different Plugs
Do these look okay?
You're list of supporting mods looks decent to me. I had a D1 on my Z28 with pretty much the same supporting mods you have listed. Just make damn sure you get a good tune. I highly suggest taking your car with the handheld to a dyno and having it custom tuned. Try to stay below 8lbs if possible.
i used a lightning maf first, maxed out right around 400 whp, im not sure how much power others have been able to squeeze out of it though. sct or an actual blow through maf should work well. +1 on stone 629 comments on staying below 8 psi on a stock engine. ngk tr6 plugs are great or autolite 103, both are 1 heat range colder than stock. as for the fuel pump i would just get a ford gt pump, much better flow, and it can support more mods down the road. i also have a afm pipe, much better that what come with a procharger. as for the new tune,definitely a new tune, with out a good tune, your engine will probabley toast itself pretty fast. good luck on your project.
