Smooth idle return
Smooth idle return
On a mustang,when we hit the throttle and release it quiqly,the engine rev down very smoothly to the set idle.
i HATE that[:@]
is there a way to make it return to the idle more like a carb. engine?
i HATE that[:@]
RE: Smooth idle return
ORIGINAL: |MusTang
i HATE that[:@]
i HATE that[:@]
Look here for details: http://forums.stangnet.com/showthread.php?t=470711
Cheaper solution is a 1/2" copper cap. Drill a 1/4" hole in the end and insert it into the IAC feed line. Revs will be much better. Cost you all of 40cents. You'll spend more time gettign the cap then making it and installing it.
ORIGINAL: jchittick
Is there anyone that sells or makes this plate around here?? I'm not to good at fabricating or machining? Anyone?
ORIGINAL: David_K
dude how do you do htat. when you make a post your name doesnt show up in the forum homepage.
spooky
spooky
I'm a ghost lol.
thaks for the answer guys.
By the way here's another thread with a source for restrictor plates:
http://www.mach1registry.org/forums/...strictor+Plate
He's cheaper, and has received good reports from buyers, but I had previously bought one from 34_ford on Stangnet. The fitment of the plate I got was perfect.
