supercharger question
I'm planning on getting a procharger installed on my 03' gt. Since superchargers shorten the life of an engine how long can I expect to keep my motor which has 35,000 miles on it if I supercharger it? Basically how long of a life span would it typically have left if it was supercharged? It's gonna be my daily driver so I need to know. Supporting mods I have are long tube header, high flow X pipe, and a borla muffler. Anyone's help would be great. Thanks.
Taken from Procharger's FAQ, which is where I assume you read this:
"Will a supercharger shorten the life of my engine or drivetrain?
That is a very subjective question, as the manner in which an automobile is driven directly affects engine life. Assuming a properly tuned system, proper oil change and engine maintenance, and similar driving, supercharging generally will not shorten the life of an engine, just as is the case with OEM turbocharging (with proper cooldown for turbochargers. A cooldown period after driving is not necessary with supercharging). This is especially true of centrifugal supercharging, which generates boost in line with engine rpm, unlike roots and twin screw blowers, whose low rpm boost can place additional strain on the engine and drive train."
Basically, have the car tuned properly, maintain it as you normally (hopefully) would, and don't go over revving on a daily basis, the blower shouldn't have a massive effect on your motor, especially if you're well within your bottom end's safe limits.
Why does the amount of boost matter? Don't superchargers give increases in percentages? Does it work like the higher the boost the higher the percentage?I'm looking to get the magic number of 400whp. That's the magic number everyone tells me that my car can make safely.
The amount of boost directly correlates to the amount of power. I think about 15 hp/psi is the average.
And 400 is usually the magic number, But 375 rwhp is a safer number IMO. Because the rods are rated at 450 bhp from Ford. 375 rwhp equates to around 440 bhp which is close to the edge but 400 rwhp exceddes that limit and is about 470bhp. But thats just my .02
That is just the way I look at it, But there have been people that have good luck/good tuning and have exceded those numbers.
So ask yourself "Do you feel lucky, Punk?"
