Huge Problem!!Need Help!NO SPARK! - MustangForums.com
Go Back  MustangForums.com > Ford Mustang Tech > 4.6L (1996-2004 Modular) Mustang
Reload this Page >
Old 05-26-2005, 11:55 AM
wasabiboys
Default Huge Problem!!Need Help!NO SPARK!
Yeah My mustang is fine but my 1992 Crown Victoria is having huge problems. I was in a local gas station(car was idling) and it died all of a sudden. Come to find out the car has no spark. Gas is getting to the engine but not getting ignited. What exactly would cause this. All fuses have been check! The crankshaft positioning sensor is alright. I am thinking it might be the coils or something that leads power to the coils. I really need help!
Anything is helpful
AIM is Blacksilverchris
Email [email protected]
wasabiboys is offline
Old 05-26-2005, 01:25 PM
badass04gt
Default RE: Huge Problem!!Need Help!NO SPARK!
I had a no spark with my camaro. Wires in the harness were broken. But check all your ignition components. The cap, rotor, coil, etc. I would try the coil first.
badass04gt is offline
Old 05-26-2005, 07:15 PM
wasabiboys
I will check it out. I think it might be an ignition module. Any trouble with that thing.
Old 05-26-2005, 07:50 PM
mrbmp
I ♥ Acer
Change the ign module.
Does that year have a distributor?
If it does check for spark at the coil.
mrbmp is offline
Old 05-26-2005, 08:21 PM
wasabiboys
no it doesn't have a distributor. It has like two coil things at the front of the block. I checked that and voltage is going into and out of it. 7 Volts to be exact. I think it might be the ignition module. I think on 96 Stangs wiht the 4.6 L it might have been a problem. I will try to change that. Could that really be the reason why it is DOA?
Old 05-27-2005, 01:29 AM
badass04gt
That could definitely be it. If you change it, make sure you use the grease they give you like the instructions say. If you dont youll fry it right up.
Old 05-29-2005, 02:10 AM
wasabiboys
Dude I checked it out. No change...I got a Different ECU and same. But what about the Crankshaft Position Sensor. You know anything about it.
Old 05-29-2005, 04:37 AM
Chanedeezy4106
It also could be your idle sensor..
Chanedeezy4106 is offline
1TUFF302
11-05-2015 05:02 PM
Golfsito
10-06-2015 12:02 PM
Omgitsa88Stang
10-05-2015 08:33 AM
TfcCDR
09-12-2015 05:13 PM
Emblazoned
09-03-2015 11:45 PM
Quick Reply: Huge Problem!!Need Help!NO SPARK!
Featured Sponsors
