want to get a trubo system
Hey! first day on this site. I am looking to get a turbo system for my car... i have an 2000 gt, 5 spd, with bassani x pipe, no cats, bassani mufflers. My question is what is the best turbo to get and what will i need to do to the motor..... can i run stock internals, if not what exactly do i have to do besides tunning at the end to make my car run on pump gas and be reliable to cruze as a daily driver. i want to get a twin turbo set up and am completly new to the turbo seen so all imput and direction is needed. Thanks.
so post the amount of power you hope to get and i will tell you my opinion!
your question is very open ended, what kind of power levels are you going for? adding boost can become a very tangled web if not thought through. trust me im in the situation now. stock blocks can usally handle anywhere from 370-420ish but anything past 400 is chancing it. Also why do you want a turbo over a supercharger? how much do you plan to mod the car in the future? these are all questions you need to ask yourself before taking the very expensive plunge for boost.
yes and no, back pressure is back pressure across the board. less strain in the way of tension on the motor, but about the same on cumbustion cycle. you have to remember that stock rings are not meant for boost on our 2v's
as for your question, its a completely different system. kenne bells, or anything other positive displacement charger like that will build boost quickly, but pull a lot less harder than a centrifical supercharger. pretty much in your case if you don't expect high numbers, its completely up to how hard you want your car to pull initially.
I wouldn't doubt it one bit! He just needs to tell us his goals so we can make a more educated decision on what he needs.
