TIMING CHAIN NITEMARE, HELP!!!
OK, just finished strapping the pi heads to my block, put on the gears and chains, not sure about how i timed it, i laid both chains down and squared the ends, then i marked each end, then i put one marked end on the cam gear dimpple, and the other on the crank gear mark and rotated slightly to take up the slack, did the same for the other side, thats the best i can describe it , does it sound rite, im using a haynes manual so its not to clear about putting on new heads, any info or tips would help
mungodrums
10-07-2015 04:01 AM
Golfsito
10-06-2015 11:02 AM
09-08-2015 11:50 AM
