Need help reducing tire spin
You can see my motor swap and my mods in my sig and my problem i think is going to be launching. I have 245/ 45 by 17 tires and when i only had like 250 260 hp to the crank i would spin when i launched at anywhere between 2000 and 2500. Im pretty sure when im over 330 to the crank there going to spin. Besides getting stickier tires what else could i do to help me launch without spinning. I was looking at upper and lower control arms. Would they help? The reason im not doing tires right now is because i just spent all that money on the motor swap and tires and rims are pretty expensive. So basically im looking to beef up my suspesion so i can launch better. Thanks
I might be on my own here, but dollar for dollar, I think tires would help you the most.
When I first bought my Mustang (used) the guy had a set of bald DR on the car. I could barely get the tires to spin. When I replaced them, I went cheap. I put a pair of cheap tires on the car and I can sneeze and the tires spin. Needless to say, I'm now looking at replacing the tires because of wheel spin and they barely have any miles on my cheap-o fix.
Oh, also up your tire size. I think you can jump to 275 on that rim without having to replace anything.
oh really? i didnt know i could go with 275's thanks. I was looking at some nittos but like on 245's cause i thought like i could only put the same tire size on. Are you absolutly sure i can go with 275?
I have six rims for my car. Four 17X8 and two 17X10.5
The original set-up was 245 on the front and 275 on the rear with the 17X8 rims.
Currently I run 245 on the 17X8 in the front, and 315 on the 17X10.5 in the rear.
I bought cheap tires for the 315's and they spin all the time, I now wish I spent more $$ on better tires.
Search some old posts, you'll see that some people put even larger than 275 on a 17X8 rim. The way the tires look and fit on the rim, I personally would not recommend it, but that's just my .02 cents
