Lowering Springs
Old 11-12-2008, 08:17 AM
agarr19
agarr19's Avatar
Default Lowering Springs
can i get away with just the springs or will i need to get other stuff?
agarr19 is offline
Old 11-12-2008, 09:03 AM
vroompshhtsi
vroompshhtsi's Avatar
https://mustangforums.com/forum/4-6l-1996-2004-modular-mustang/57279-lowering-your-94-04-4-6-gt-mach-1-cobra.html
General rule is if you lower your car more than 1.5" you should get aftermarket shocks/struts and cc plates.
I lowered my 03 GT with Eibach pro-kit (1-1.5") and nothing else (no shocks/struts or cc plates). So far it rides pretty much exactly the same as stock. Stock ride wasn't good so obviously it still sucks.
vroompshhtsi is offline
Old 11-12-2008, 09:06 AM
blee69mustang
blee69mustang's Avatar
if your gonna go professional racing, and still want the geometry of your turning right. might wanna get your spindles raised. but you'll need bump steer for sure. and recommended that you get caster/camber plates as well. you could get away with just springs tho. please don't cut them tho.
blee69mustang is offline
Old 11-12-2008, 09:25 AM
H0SS302
H0SS302's Avatar
why cant you cut them. they are not progressive rate springs, in no wy shape or form is cutting your stock springs bad for them or your car.
H0SS302 is offline
Old 11-12-2008, 09:27 AM
MineralGrey
MineralGrey's Avatar
I would say that if you are exceeding 1.5" if not I would still recommend at least tockico shocks & struts.
MineralGrey is offline
Old 11-12-2008, 10:58 AM
blee69mustang
each spring is made to with stand a certain amount of weight. but cutting your springs your going to start messing up your suspension. your gonna have less coils to take impact. its way better to get new springs. the springs are made a certain stiffness to transfer power under accelerating braking so on. but by having them to soft(or cut) could cause you to bottom out while braking and could make the car plow through turns(bad handling). ya its good to lower your car. but also if you accidentally cut your spring you could bottom out every where and loose control suddenly(seen it before on a track, guy rolled his car because he did exactly what your dong.)
Old 11-12-2008, 12:48 PM
H0SS302
H0SS302's Avatar
The stock springs have a static rate regardless of coils present, they are not progressive.. ppl have been cutting there springs for years and years and years; as long as u dont clip more than a coil coil and a half you should have ZERO issues.
H0SS302 is offline
Old 11-12-2008, 01:26 PM
GTRACER88
GTRACER88's Avatar
I have been driving around on a 2 inch drop for over a year. No C/C plates, no after market struts or shocks, just rotate the tires and balence them regularly and you will be fine.
GTRACER88 is offline
Old 11-12-2008, 02:18 PM
lizzyfan
Underboss
lizzyfan's Avatar
Go with poly bushings, get rid of stock rubber bushings
lizzyfan is offline
Old 11-12-2008, 03:33 PM
Young_Buck
Young_Buck's Avatar
Ive been rollin on 2in drop front and 1.5 in drop rear. You can do it without other "stuff."
Im gonna get struts and better shocks. Maxspeed springs FTL unless lookin like sex is what you want.
Young_Buck is offline
Quick Reply: Lowering Springs
