Wierd Water Passenger Side
My boss called and said I had a big puddle under my car. I went to check it out. i found water dripping from the passenger side exhaust pipe. I did not run the ac this morning. I moved the car to another spot. Found water dripping again. No idea where its coming from. Any thoughts?
is it clear or green?
THe AC kicks on by default whenever the defroster is used unless it's an S197. S197 (05+) models have a seperate AC button to control the AC apart from the vent controls.
older models kicks the AC on anytime you run the vents to the right of the center position (off) or AC is stated on the vent option.
jwog666
12-27-2021 08:09 PM
