What size drag wheels/tires?
I want to run a drag radial, which would be a better option, running a 315/60/R15 (30'' x 13.5'' - 15'') with this wheel?
Diameter & Width: 15 x 10''
Bolts & Bolt Circle: 5-4.5''
Back Spacing: 4.5''
Or running a 275/40/R17 on a stang wheel? Or a 315/35/R17 on a 10.5 rim like I am using now? And it that the correct bolt pattern and back spacing?
Back Spacing: 4.5''
A 30'" tire would be super overkill dude.
That would be like runnin on 3.27s (or 2.73s if you have stock gears)
What kind of gear do you have in the car? I'd suggest puttin some 275/60s on there (28") The bolt pattern looks right, and Im not sure on the backspacing but it sounds correct also.
im currently looking at getting either 275/50/15 or 325/50/15
which of these do i need?
01 gt
http://store.summitracing.com/egnsea...splayPrice%7C0
01 gt
01 gt
01 gt
Get the 275s, they should be near 28"
Anything taller would need a 4.30 gear or higher to take advantage of in our cars.
A 275/60/15 is about 28" tall
I guess the 315 is about the same at around 28"
I dont think he would need something that wide unless he's making some serious power
And I know how tire sizes work thanks....dont know what I was thinkin when I posted that
