HELP: Intial Engine Start-Up
my pickup tube went on with no problem, the nut that tightens down onto the main bolt should be threaded all the way on and torqued down. I agree with one of the previous posts- you will need to crank a little longer than that. you should have used assembly lube when you built the engine, it wont hurt to crank it a little longer.
I did an older pushrod build last month and I primed the pump with a drill. I went through both batteries on my 14.4v Dewalt and still had no pressure on the guage. I slapped everything together and started cranking it. It took about 20 seconds of constant cranking before the oil pressure acted like it was on Viagra....lol You just need to keep on cranking away. Your probably gonna need to put a battery charger on it and let it sit overnight because it may take that long. I would rather turn a dry engine over and over by the key than have it fire and not get any oil pressure. Just don't sit there for 5 solid minutes and crank as you will eventually begin to build up heat.
I used 10w 30
So what im going to do is
1st take off my oil filter and pour oil into it
2nd get a oil pressure sending unit
3rd drain some oil out of my engine (right now i have more then 6 quarts in)
4th Charge my battery somemore
5th Crank it for around 20 seconds and see what i get.
Does that sound like a good idea guys?
Ohhh oil press. ha you ment oil pressure sending unit! lol i was like wtf is a oil press?
AmericanMuscle4.6GT
11-10-2015 02:06 PM
TfcCDR
09-14-2015 12:08 PM
