power steering pump removal
What is the best way to remove the pump? The last bolt I need is behind the high pressure line, and I cant get a wrench on the line because the damn pulley is in my way. I'm pulling my motor and that's the only thing left! Thanks.
Get a ratchet wrench with a slightly angled end... 10mm..
You can snake it in there and unbolt the last bolt with pulling the pump away from the block at the same time.. I did it when I removed my motor
