no start
You dont need to drop the tank to check it.
If you have power and ground going to the pump, and no fuel pressure, then you have a bad pump. Unplug the pump connector right next to the gas tank, and check the red wire with black stripe (or possibly the brown/pink wire) for power with a test light when you turn the key on (it should only have power for about 2-5 seconds so you'll need another person) Next check for ground at the same connector, black wire. Hook up to the positive side of the battery with a test light and probe the black wire. If it lights up, then you have ground.
dalefrancis88
09-11-2015 07:15 AM
