SVT focus fuel pump??
For now no I have 113k on the clock and it's not a built motor. I figure I'll run this motor till it goes then build something similiar to what your building. I'm working on getting a new job right now if I do the new motor will be coming sooner then I thought. Your in the military right??
You just have to take the pump outa the basket and slap the new one in. If you run 8 lbs with a good tune you should be able to run that stock motor until you get tired of it. Watch that focus pump though without a BAP. I burnt a valve at 10 lbs of boost due to a lean condition at 6500 rpms.
Yea I agree with contentsunderpressure, when mine was dynoed for the first time with a focus pump it was getting a little lean in the upper rpm, so we went with a corba fuel pump rated at 300lph and done the swap. Its made to work with are returnless fuel systems.
