Are all subframe connectors....
Old 11-16-2008, 09:23 PM
livefast1
livefast1's Avatar
made mine also out of square tubing just bent them to the same dimensions as the stock ones and welded em in.
livefast1 is offline
Old 11-17-2008, 04:18 PM
Soldier GT
Soldier GT's Avatar
I should have asked this question first, exactly what are subframe connecotors good for? I looked it up on line and got alot of jibber jabber. For the guys that have installed the subframe-connects did the car ride better, performance etc., etc.,
Soldier GT is offline
Old 11-17-2008, 04:30 PM
StriderTacticaL
StriderTacticaL's Avatar
Didn't you PM me asking the same question?
StriderTacticaL is offline
Old 11-17-2008, 04:45 PM
SSFenris
SSFenris's Avatar
Originally Posted by Soldier GT
SSFernis thanks for that info. I will most def buy full length. What were so bad about your LRS's?
What WASN'T wrong with mine would be a shorter list. The 'standard length' definitely DIDN'T cut it, and my car is only 310rwhp. My buddy basically tack-welded them with a 110TIG (not the 'frames fault, I know, but still part of what's pissing me off about them) and didn't put any kind of paint/corrosion inhibitor. The standard length sfc's also bend/warp when you try to jack your car up on them (I figured, since they were supposed to be 'frames' that they could be jacked against). The coating that came on them is JUNK, flaked off in TX in under 6 months (no snow, no ice, no salt). I think that's enough for now.
SSFenris is offline
Old 11-17-2008, 04:46 PM
avlon06
avlon06's Avatar
keeping the chassis stiffer, good for both straight line and twisties
avlon06 is offline
Old 11-17-2008, 04:49 PM
SSFenris
SSFenris's Avatar
what are they good for? a good subframe connector SHOULD prevent flex in the floorpan, which in turn prevents body roll. Basically, it's supposed to make the frame more rigid, which is a good thing. If you've ever seen a high-powered Fox without subframes launch at the track, you know what I'm talking about. The whole body twists. And, since you're putting stress on a METAL frame, there's only so much that said frame can take before it STAYS that way (it's called springback, but that's another story). Foxes were notorious for this problem, verts especially.
SSFenris is offline
Old 11-17-2008, 07:16 PM
Soldier GT
Soldier GT's Avatar
Yes I did Pm you and thanks for the advice. Wanted to hear someone else's point of view especially since I am about to buy them.
guitarman376
10-11-2015 01:47 AM
mikesr4565
Suspension
09-21-2015 10:26 AM
09-17-2015 07:57 PM
09-16-2015 07:53 PM
09-08-2015 11:50 AM
Quick Reply: Are all subframe connectors....
