h/c combo
h/c combo
well just want to know if this setup is going to work well will the cams out flow the heads
i have a set of cms stage II cams and looking to do heads at the same till the foxlake stage II heads ?
any input would be great
If you're getting Fox Lake Stage II heads, you will be very pleased with the end result. I have a hard time understanding your threads. Foxlake also sells comp cams (i believe) and if you wanted a custom grind, they could do that for you.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
