Couple odd issues
Couple odd issues
Issue 1- So for some reason when I have the front defroster on, my idle likes to jump between 500-1000 up and down. Idle stays perfectly smooth with any other heater setting. I cleaned the iac and maf, replaced the pcv and battery, and put it new plugs. Any ideas?
Issue 2- After my car sits for hours on initial start up my oil pressure gauge will be all the way in the red on L, after a few minutes it goes up to its standard position. On a warm start up it will always go to the normal spot it stays in. Is it the switch? I read the tsb for 99-01 mustangs that describes exactly what mine is doing, any thoughts are greatly appreciated.
If the IAC is not behaving properly the idle will jump as you describe when the AC kicks in--in fact that about the only thing that would cause that behaviour.
I realise that you cleaned it, and that some have had success in doing that, however the shop manual states quite clearly:
Note: The IAC Valve Assembly is NOT ADJUSTABLE and CANNOT BE CLEANED.
LivingInThePast
09-16-2015 12:20 PM
