Stock fuel system
That's nice, but he said STOCK
Not professionally tuned, calibrated, etc...
Unless the TS has subliminal messages I'm not getting...
It was a simple question about stock capabilities, and people come in talkin about pumps, injectors, MAFs... It just makes me laugh sometimes..
I did some research on the fuel pumps, FWIW the '03 and '04 s/c Cobras (390 HP at the crank) use the same fuel pump (Motorcraft PFS170) as the GTs.
So the GT fuel system should be good to at least 315 to 320 rwHP.
It's actually dual fuel pumps that are used on the Termi's
No, i haven't done anything to the fuel system. Hence the thread. I have heard of people making about 400 whp with the stock fuel pump. Isn't the fuel sytem a return style stock? Its sounds like the injectors are what is the biggest limiting factor?
You are return style like myself so if you are going with boost you'll need a 255LPH pump, 42lb injectors and at least a 90MM MAF
