i need hlp and or advice
Yeah I could possibly see like I said earlier $600.00 for parts and labor. If the install is $600.00 the gears and neccassary parts will be close to $300.00 with tax and everything added, you're talking close to a $1000.00. For gear install that's crazy!
On a high mileage stang (120k+) while you were in there might as well do new axle bearings/seals, lsd clutches, basically full rear end rebuild. Then youre talking probably close to 1000 with parts and all.
Ive seen shops charge 600 for gears and install. so 400 for install. Book time for installing a ring and pinion with bearings and all come to right at 5 hours labor. $80 an hour is slightly less than what dealerships around here charge.
Agreed its way too much. Ive just heard shops charging that much.
Come on bpark8824 if you had a problem with this guy posting this thread then you shouldn't responded or wrote anything. I like to also double maybe triple threads so that I can get everyone's point of view. Well enough on that.
One of you guys posted that a gear install would be $600.00. Man that is to much for a gear install. Does that include parts and labor? My install at a speed shop here in Missouri was a $250.00.
To my man who started this thread, I agree with the other guys mos def if auto-410's and also a tuner.
Omgitsa88Stang
10-05-2015 07:33 AM
