Door Adjustment Help
Take it to a body shop for new pins and bushings. The parts don't cost that much, it is more in labor, just find a shop that will do it for ya. Unless you feel up to it, but you will need a hammer and a set of punches and a can of lithium grease.
My brother and I tried to undo the hinge bolts and adjust the door some that way. It's worse now than before. I'm going to take it to a body shop on Monday. The one my family has had good experience with in the past. I called him up and he said it probably needs new pin and bushings and it's not a big deal.
Update:
I took it to the body shop today and he said he can adjust it for me tomorrow for about $100.00. He called about new hinges which are $115.00 and with labor would be a total of $250.00 to have both hinges replaced. However, he said if it was his car he would just adjust the current hinges since it wasn't that bad.
Tomorrow I'm going to drop it off for the adjustment only.
