Mach 1 n20 fuel question
Ok guys i dont post on here much i just like to read stuff. But i can not find anything about my question. i will give you a quick run down on my mach 1. This is what i can think of right now...
The motor: 03 cobra iron block, manley hbeam rods, j&e pistons close to stock compression, ported heads, stock intake manifold, crower
stage 2 cams. NX wet kit jetted for 125 right now. SCT flip chip, Kooks lts o/r x with bassani catback
fuel system upgrades: 03 cobra tank, KB BAP, 03 cobra fuel pumps.
drivetrain: PMP3650, 10.5inch spec stage3+, 10.5inch AFM aluminum flywheel, MGW shifter.
rearend: auburn pro 31spline posi, FRPP 4.10 gears, moser 31spline axles, braced axle tubes
suspension: UPR UCAs, HPM megabite jr LCAs, front sway removed (will include with car.)
I want to run a stand alone fuel system for the nitrous but i am having a really hard time finding a full kit for a mustang. If anyone knows where i can get a complete setup that would be great. I want to run a 200 shot for now until i can make up my mind on a progressive or two stage set up. I also want to get rid of the KB BAP. Do yall think i will be ok running focus pumps? Sorry for the long post i am just tired of looking around i need answers haha.
Thanks
Thanks
Attached a pic of mine, that mounts on the radiator support, hangs in the gap between the radiator hose, had it for a while now. Have only gone through about a 10# bottle. Dont currently have it on the stang right now. Yell if you have questions, also have a friend that just moved the battery, mounted a fuel cell there, then just a external regulator and fuel pump. Kits are a cleaner install though.
Check out. http://www.nitrousoutlet.com/catalog...roduct_id=2829
will let someone else do it for the fuel. Should be good on the focus pump. Never looked up what the cobras on what they are rated, but would have assumed even those without the bap would be good enough for the motor.
