fuel upgrade questions
02gt with a n/a 03 cobra 4v. Motor currently has a direct port kit (never sprayed) but planning to install a tubro when funding allows. On a mustang dyno the car made 250 hp & 260 ft/lbs on motor with 8.5:1 compression. I plan to spray the car with 200, but i have to upgrade the stock fuel system. Is a gt500 pump a direct replacement? Not really interested in breaking the baffles to drop in a cobra hat. Was thinking about buying a 03 cobra tank. I do have a kenne bell BAP and a wiring upgrade, but they are not installed on the car. Would a single gt500 pump and a BAP be enough to keep my gt tank when i install my turbo or would i need to swap to a double pump setup? New to the 4.6`s, other car is a 95gt......which is forsale, not enough cash for one let alone two
