Center Console E-brake
I HATE this part. I upgraded my 99' cobra console to an 01' one. This was the worst part, it sucks. You just have to move the console around in different angles. I pulled the break up as far as I could and did that. It probably took me an hour of bending, turning and yelling to get the dam thing out. Good luck to you.
It isnt THAT bad... You are going to have to slide the boot up as far as possible then sort of turn the console and pull up at the same time. Make sure the e-brake is jammed all the way up. Then carefully slide it out, The console will bend a little, just be sure not to scratch the **** out of your seats and dash
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
