intake manofild
Old 06-02-2005, 02:28 AM
the07sniper
the07sniper's Avatar
Default intake manofild
what is wrong with the stock intake manifold on my 99 cobra, what is this "the fiX" that had to do with the intake manifold in the 99 cobras that has got me so worried, anyone know?
the07sniper is offline
Old 06-02-2005, 02:39 AM
Cajun
Cajun's Avatar
Default RE: intake manofild
Get a aluminum one.. The problem is its plastic and it can't handle all that pressure.. If you had a supercharger it would shatter..
Cajun is offline
Old 06-02-2005, 02:41 AM
Cajun
Cajun's Avatar
It sounds like you got the money so just get a new manifold. Your pushing close to 400hp at the crank right?
Cajun is offline
Old 06-02-2005, 03:06 AM
The02GT
The02GT's Avatar
ORIGINAL: Cajun
I dont think hes supercharged, your intake mani is fine you dont need an alumi. one plastic will not heat up like alumni. would
The02GT is offline
Old 06-02-2005, 12:54 PM
neogenic83
neogenic83's Avatar
i thought only GT's had plastic
neogenic83 is offline
Old 06-02-2005, 12:57 PM
code3GT
Mustang Nazi
code3GT's Avatar
Ford has announced that a production problem has prohibited the '99 Cobra from making the full advertised (as designed) HP and torque. The recall program announced by Ford has become popularly known as "the fix". It is also popularly misunderstood by certain uninformed quarters.
The recall was installed in "beta" form to about 100 cars in the late fall of 1999. This early program was a milestone designed to test the manufacturing and distribution programs created for the program by SVT. Once tested (and verified), the recall program is set to begin in late November and early December 1999. It is anticipated that, given customer's schedules and the weather in the northern areas of the country, it may take until the spring of 2000 to update all the cars.
The recall program brings the cars up to 2000-spec level (all 2000s will have the same exact parts). What's being updated?
the lower intake manifold (new and Extrude-Honed, not remanufactured)
the exhaust behind the converters ("cat-back"). Now mandrel bent!
the engine calibration - via a reflash of the Powertrain Control Module (not a PCM replacement)
code3GT is offline
Old 06-02-2005, 04:37 PM
SilverGTV8
SilverGTV8's Avatar
Not even close buddy......
They had runner issues on the back 2 cylinders that caused intake flow issues, as well as, exhaust piping issues. SVT replaced the intake and exhaust to correct the issue.
The plastic manifold is more then capable of handling the pressure of forced induction to a limit, which would not be commonly met on a street driven car, and by the point the manifold would be typically be custom sheet metal intake.
The intake won't shatter in a street blown application....
Where do you guys get this stuff......
ORIGINAL: Cajun
SilverGTV8 is offline
Old 06-02-2005, 07:07 PM
Jglisson
Jglisson's Avatar
Rumours abound...amazing
The plastic intake won't shatter. The problem is a constant high temperature exposure with a mix of cool air running through the intake over XXXXXX miles. This will finally yield a crack or fracture in the plastic.
Jglisson is offline
Old 06-03-2005, 02:36 AM
David_K
David_K's Avatar
what if you study dynamite in it? huh? bet it'd shatter then!
David_K is offline
Old 06-03-2005, 05:58 AM
Cajun
Cajun's Avatar
ORIGINAL: Cajun
"If" he had a supercharger the pressure from the supercharger would shatter it! STFU kid go back and read up more on ur specs
Cajun is offline
Quick Reply: intake manofild
