squeakin'?
squeakin'?
hey everybody, i currently own a 1998 mustang gt (5 spd), great condition, quite a few miles on it, just over 170,000 but still runs like a champ. I am only having two problems, which may not even qualify as problems to you, but i've become a neatfreak kinda guy so heres whats up. my biggest issue is when the car is just sitting in neutral, there is a squeaking sound, which really sounds like the throwout bearing, but i really cant be too sure, when i get a chance i will try to record it. Next, whenever i get on it in 3rd gear and up, a little over 3K rpm, right on the other side of the firewall from the dash, theres is a very quick rattling sound, i have people listen to it but no one knows. i would appreciate any ideas you guys have, i know you can help, thanks!
T/O bearing sounds like a chirping, does it go away when you push in the clutch? could be your idler pulley with that many miles or just the belt needs replacing
the same things going on with mine. fixed problem 30k ago when i put in king cobra clutch, t/o bearing, etc. now its back and it sounds like a bearing in the tansmision is out when in nuetral. don't mean to hijack thread just experiencing same thing u are
The squeaking definitely sounds like the TOB. Mine was doing the same thing and after I replaced the TOB and the pilot bushing the sound went away.
About the rattling sound, what kind of exhaust do you have? It could be the drone resonating through the car causing that rattle from the dash area.
