I can't remove my oil filter....
#22
lol ^^^ ive done well over 500+ oil changes in my life and ive NEVER had the screwdriver trick not work so thank you very much!!!! like said before its to be used as a LAST RESORT!!!!! so try everything else first and if they all fail try the screwdriver!!! ........lol shouldnt be changing your own oil!!!!!! funny sh*t.......
Mustang filters aren't difficult anyways IMO, they are easily accessable. Want to talk about "fun" cars to change oil, lets talk about German cars....
Nic
#23
i was just replying to your comment that "NEVER use a screwdriver on an oil filter! If you do so, you shouldn't be changing your own oil." ive never owned a strap wrench to remove an oil filter. if i cant get it off buy hand i will let the car warm up and then the gasket will become warm and will 99% of the time will loosen right up, if it doesnt i take a screwdriver and do it that way. also my mark VIII you couldnt get a strap wrench on it with out removing the oil cooler lines, lower coolant hose and power steering lines. so the strap doesnt work with every make car.
#25
Well, I have a part time job in my father's quick lube garage doing simple stuff like changing oil, rotating tires, etc., so I'm not removing my own filters, I'm removing other people's filters who decided to use something like a Fram grip-filter and about 1000 pounds of torque to put the filter on. So, I'm a bit **** about that. Im sure Jbauer understands^
#27
#28
#29
Location: vids> http://vids.myspace.com/index.cfm?fusea
#30
jwog666
12-27-2021 08:09 PM
