strut install question
alright so i was board as hell tonight so i decided to try to change my struts. when u guys do this do u take the brake calliper off to make it easier to access the bolts. and another thing the strut bolts are tourqed pretty tight on there like 145flbs.
I can't remember exactly what I did to get mine out, but I just followed the instructions of the haynes manual and it was all pretty common sense. I do remember having to put some muscle into it to get those bolts off. I used a 12" pipe on the end of my rachet.
Definitely take the caliper off and secure aside with a coat hanger or something similar. I used an impact gun on mine but the pipe method should do fine. You can also try soaking it in penetrating oil if you have some.
You don't have to take the caliper off, but if you feel it'll make it easier, go on right ahead. I used an impact so i took the easy way out.
Use a breaker bar and use short powerful blows to knock out the stubborn bolts. Don't forget the PB blaster.. and don't forget to support the LCA
got em on and it only took 4 hrs lol. those knuckle bolts were a pain in the a** to get off. they were rusted pretty good in there, but i shot the with some wd40 and used a 4 foot breaker bar lol and eventually they came off. In the haynes manual though, it said to make sure to line up the paint marks to insure proper allignment. i had kyb struts on there before and they're weren't any marks on them. prob not a big deal but no matter what the allignment would stay the same right???? anyway thanks for the help guys!!!!
