how f***** am i?
how f***** am i?
Driving home tonight in the lovely single digit temps. Car started lurching some. I'm doing 40ish mph in 5th gear going up/down hills so i assume its just from getting on/off the gas to maintain speed.
As I am coming to a stoplight the car lurches hard, revs up to 3k and drops (in neutral). As i stop at the light the idle bounces from 300 to 1k. I am about 1/4 mile to my house. I realize as the light goes green and I make my left turn i have NO OIL PRESSURE...I decided at the time I was close enough I should be able to limp it home...I am about 500 feet from my house and the engine makes a very sweet metal grinding on metal sound...i am at 1200rpms limping it up a small hill to pull into the parking lot at my apartment complex...
Park it. Get out, nothing dripping...Temp Gauge never went past 1/2 way.
I get the joy of going out in single digit temps tomorrow, while watching my 8 month old son while the wife works, and trying to figure out what happened to my car. I am worried more that the engine is screwed from driving it with no oil pressure. Sitting here now I feel I should of coasted down the hill from the light and pulled into the closest parking lot, which is about 50 feet from the light.
Was having the best day ever, went to my first NFL game, 49ers beat the Rams, amazing...now this **** ruins everything.
I had a fun time once replacing a starter and some other goodies on a 89 Saab once just to find out that the oil drain plug somehow got knocked out and there was no oil in it. Bye bye Saab.
Check your fluids and go from there, prey for a shorting computer or something and not a dead block.
Hindsight is always 20/20. Have you filled it up with oil and started it up? Any road obstacles (hideous potholes, chucks of ice) that could have made the nasty sound?
I took my car in to have the oil changed, less than a quart came out. And that's including the half-quart of oil conditioner I put in that morning. The gauge on the dash lied to me. Anyway, had the oil changed again last week with no issues. Mine survived (admittedly with no grinding noises), perhaps yours will too.
I don't mean to get your hopes up, as it does sound bad. But do what you can. Good luck..
oil is fine...no leaks, oil is just below the 'full' line.
my only assumption is the oil pump went out...or the gauge is lieing...but it made horrible metal grinding sounds...and if i blipped the gas they got much worse.
If you got filings in there, your pretty much toast.
Time for a 4V swap.....
Lynn
