Nailed curb bad vibration
Old 12-23-2008, 09:14 AM
MJH78
MJH78's Avatar
Default Nailed curb bad vibration
I hit a damn curb the other day. I was going fairly slow just pulling up to a house and I was distracted looking for the house number and I hit the curb. When I hit it it actually sounded like I hit the rim on the curb because it had that type of metal striking something sound but..no scratches at all on the rim. hadn't driven in it in a few days and got it up to about 65 this morning and it vibrates BAD. So what do you guys think...did I bend the axle or something?
MJH78 is offline
Old 12-23-2008, 09:54 AM
Ultimeas
Ultimeas's Avatar
You might have just bent the rim. Just jack it up and shake the tire left to right, then up and down (very slightly), everything should be tight.
If it is, take the wheel off and try to get it rebalanced. Anyone who balances tires should see if its bent when they try to rebalance it.
Ultimeas is offline
Old 12-23-2008, 09:56 AM
MJH78
MJH78's Avatar
If it is a bent rim, can that be fixed or would I need a new rim?
MJH78 is offline
Old 12-23-2008, 11:46 AM
jrherald420
jrherald420's Avatar
if you cant afford a new rims you could TRY to somewhat fix it buy removing the tire and taking a hammer to the part thats pushed in but that normally only works on the cheap steel rims.
jrherald420 is offline
Old 12-23-2008, 11:59 AM
vanquish
vanquish's Avatar
I'm assuming it is a rear tire you hit because you mentioned an axle as a possibility for what's wrong?
vanquish is offline
Old 12-23-2008, 08:34 PM
MJH78
MJH78's Avatar
No it's the front right tire. I guess I meant tie rod, not axle. Anyways, upon further inspection I scratched the hell out of that rim. I didn't notice anything bent though. Guess I'll take it in and see what the verdict is.
MJH78 is offline
Old 12-23-2008, 08:44 PM
vanquish
vanquish's Avatar
oh that makes a difference. There are a lot more variables when it's a front wheel because of all the suspension there. I would do the easy stuff first and get the wheel checked out.
vanquish is offline
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Nailed curb bad vibration
