Need a new engine... and advise
I've not yet decided what I will do if and when I need a new motor, but I've been considering dropping in a newer 3-v motor from a salvage yard. You should be able to get a low mileage motor fairly cheap. I've had used motors put in before and have always had good luck with them. (I don't use e-bay.) You can buy a kit to adapt the 3-v to our cars and you use your stock wiring harness and computer. Unless you can rebuild the motor yourself, you are not going to get a forged motor for $2,000.
Edit: The 3-v heads flow almost as good as the 4-v and according to Wikipedia Ford no longer makes a 4.6 4-v motor.
I need a new engine for my GT. Should I get a used 4.6 if money is a problem? I have been looking on Ebay and http://cgi.ebay.com/ebaymotors/99-00...Q5fAccessories is an example of engines I could pickup on Ebay. What should I be concerned about when buying a used engine like this and would it even be a good idea at all to pick an engine like this up?
Also if I do pickup a used engine what should I do to it following the install?
DrunknRuckus
08-23-2015 10:05 AM
