mach 1 gauges speedo off by 5 mph
i installed a mach 1 gauge cluster on my GT and everything works perfect, except the speedo is off by 5mph...i thought maybe because machs have 3.55's but what do you guys think-
It may be because Mach I's came with 3.55 gears, however I was not aware of any differences in the cluster's servo motors. Did you swap the electronics from your old cluster, if not how did you deal with PATS?
Also, if it's 5 mph off at all speeds then it's a needle placement issue, not gearing related...
yea i swapped the circuit board off the stock cluster, everything else is accurate because i checked them off the digital diagnostic readings but i'll just move the needle...i was just curious to see if this happened to anyone else
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
