dont use loctite if you want to seal it i always put a little hi temp silicone sealer on my fittings threads. you really want it to be tight though on the pressure side.
Sorry I hadnt seen this earlier. There is a metal plug that screws into the oil drain hole next to the filter. Remove that and install the vortech t-fitting in its place. Attatch the oil feed line to the fitting. Then on the other end of the t-fitting, you will install the oil pressure sending unit. Take the metal plug you removed from the drain hole, and install it in the hole that the oil pressure sending unit used to be in. So basically you are installing both the t-fitting and the sending unit into the oil drain hole and blocking off the other one hole. Thats how mine was setup.
