need help!
need help!
noticed a leak on the drivers side this morning, antifreeze!! all was dry up top except for around the thermostat housing. not sure if its the gasket or the intake itself. just in case and might as well, where can i get a good intake from? performance one? thanks!
99% chance its the crossover or t-stat housing.. Dont look into aftermarket intakes, stick with a new PI unit. They are relatively in-expensive as well...
http://www.americanmuscle.com/intake-manifold.html
They hold up great man, that intake is the same PI replacement "new style" intake from Ford. You wont need anything extra, it will bolt right up to 99-04 2vs no problems. I'd look into an intake gasket kit, but thats just for piece of mind, the original gaskets are "re-usable" I'd also look into new spark plugs. And when you replace the intake, make sure you pull all 8 plugs, shut the fuel off, and crank the engine over a few times and clean out the cylinders of coolant before you install the new intake. A lot of people skip this step and its easy to bend rods
