97 gt questions
Old 01-04-2009, 01:48 PM
97gold
97gold's Avatar
Default 97 gt questions
i have a 97 gt with a 01 engine should i go with nitrous or meth injection.Also i have a 97 ecu should i get a 01 ecu will it add more power.Does a bad o2 sencer have anything to do with power loss or gas milelage
97gold is offline
Old 01-04-2009, 03:32 PM
Darkcrime
Darkcrime's Avatar
It all depends on what you want to do with your car. If meth or nitrous is your only option, I would go with nitrous.
The 97 ecu was made to run with the npi parts (heads/cam/intake) so honestly, I would buy a chip rather than the harness (plus, with a 2 stage chip, or sct, you can run a tune for nos and one for normal driving).
o2 sensor can cause your engine to run rich, in turn, you could lose some horse, but to be honest with you, you probably need a tune anyhow with that new motor (because of the PI Parts).
Darkcrime is offline
Old 01-04-2009, 03:44 PM
97gold
97gold's Avatar
thanks; what tuner is good for me
97gold is offline
Old 01-04-2009, 03:56 PM
97gold
97gold's Avatar
whats a good tuner for me. should i get a tuner for a 97 or a 01 mustang
97gold is offline
Old 01-04-2009, 07:22 PM
Darkcrime
Darkcrime's Avatar
find a tuner that'll work with your car. check out sct tuners (check out Brenspeed.com)
Old 01-05-2009, 05:56 AM
uberstang1
Chupacabra
uberstang1's Avatar
It depends what o2 sensor is bad, if its a pre-cat sensor it could affect the car, but if its an o2 sensor after the cat it will not affect the car. The only thing the rear o2 sensor do is make sure the cat is functioning properly.
uberstang1 is offline
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: 97 gt questions
