You could, but it is wider, and I'm not sure if the brake lines on your car will stretch out that little bit. Im not 100% sure on that though, I'll let someone correct me
The older 8.8s are narrower than the 94-98 8.8s and the 99-04 rearends are wider than the 94-98s, you can use any of them if you offset your wheel spacing, just keep that in mind.
