PI swap info
PI swap info
OK, so im now 85% sure im buying a pi head swap from my friend back home. I've hear changing the headgasket bolts is recommended. My question is, if my engine only has 37k on it, do i need to change them, i was looking at prices and its a lot for the package, 300 for the gasket set...eeeesh, almost as much as im paying for the heads themselves.
this package im buying includes:
heads (ported)
pi intake
injectors +mass air (24 lbs)
valve covers (01)
gaskets for intake
im going to need a few extra things i know, but i wnt to know what you guys would do in this case??? thanks guys
heads (ported)
pi intake
valve covers (01)
gaskets for intake
do you mean the head bolts? if so you have to change them, they are torque to yield bolt (TTY) and are a one time use, go with arp head studs, much better choice. only thing i didnt see was the cams on your list. and yes those freaking gaskets are expensive. one more thing, does your intake manifold have a metal cross over for the coolant or is it plastic? if its plastic they are prone to leak. good luck on your conversion.
damn, lots of money, it doesn't help that i'm pumped about getting these heads, he is giving me a deal so i guess i will do it right, i was also wondering... What about the alt. bracket, is this really vital, i mean, the two main bolts on the alt. hold it in place, can i fabricate something in here, or am i way way way off?
if they are windsor youll need the valve covers because they have more bolts than your romeo ones. as far as the alt. bracket, when i swapped to a newer intake with the metal cross over the top alt bracket didnt work so i just drilled new holes in my original one to make it work.
