96-98gt vs 99-04 gt
Old 01-13-2009, 02:54 PM
nitrous_fed_03gt
nitrous_fed_03gt's Avatar
Default 96-98gt vs 99-04 gt
so besides the heads, what are some of the other major differences performance wise between the two? is there any difference in the block? is it really that hard to swap out the heads? ect.... thanks
nitrous_fed_03gt is offline
Old 01-13-2009, 03:01 PM
justinschmidt1
justinschmidt1's Avatar
Its the heads cams and intake...
the cams and intake are actually a lot more of a bottleneck than the heads.
Swapping pi cams and intake on a 96-98 will bring it up to about PI power level(99-04)
Pi swapped 96-98 cars will generally make 10-15 more hp becuase they get a bump in compression over 99-04 stock.
Thats pretty much it as far as performance....
I believe a lot of the 96-98s had like 2.73 gears in them too
justinschmidt1 is offline
Old 01-13-2009, 03:37 PM
nitrous_fed_03gt
maybe i will just do the cams and intake manifold and leave the npi heads on since the tad bit lower compression will possibly benefit my since i go the nitrous route.
Old 01-13-2009, 04:08 PM
justinschmidt1
I think nitrous actually works better with higher compression?
Boost likes lower compression but im pretty sure nitrous likes high compression, someone correct me if im wrong.
You would be better off doing the full pi swap and then run nitrous.
You could also just do pi cams and intake...its up to you
If you have the money just do the full swap with some long tubes.
You should be able to make around 270 rwhp with a pi swap, l/t, and tune
Old 01-13-2009, 04:21 PM
stangalator
stangalator's Avatar
im pumped to get my ported pi heads, finally, i wont be embrassed when someone asks how many horse it has, and i dont have to say.....215, hahah
stangalator is offline
Old 01-13-2009, 06:54 PM
562cobra
562cobra's Avatar
the other difference is in the mid pipe, 96-98 have 2 resonators and 4 cats. the 99-04 have 4 cats.
the Heads are a must to open it up in power.
562cobra is offline
Old 01-13-2009, 07:29 PM
lizzyfan
Underboss
lizzyfan's Avatar
98 is one of a kind as in b$stard!
lizzyfan is offline
GimpyHSHS
09-18-2015 12:27 PM
Mikett
09-07-2015 05:10 PM
MustangHead91
08-23-2015 09:37 PM
New Era Performance
06-22-2004 11:20 PM
Black Horse
01-13-2004 04:45 AM
Quick Reply: 96-98gt vs 99-04 gt
