Just upgraded to cobra calipers and rotors...
I just upgraded to cobra calipers and rotors on my 1996 gt and im not getting a firm pedal like i used too. I have to push about half way down on the pedal to start feeling any serious braking power. i figured this just isnt right and took it to Brake Specialist and they bleed out the system after i already had once and the pedal still has the same feel, not firm. They couldnt find out what the deal was either :/ So even the professionals couldnt even figure this out.
Any idea's what would be wrong???
Is the bleed screw facing up?? Did you reuse the old crush washers, or did you use brand new ones??
Also, how many miles are on your car?? Only ask because chances are your Master Cylinder could be worn, but adding more effort to it could've maybe took out a seal on the plunger..
JT
JT
+1, it did take me a while to get all of the bubbles out, even after I accidentally put the bleed screw on the bottom..
I also found it easier to bleed brakes on a Non-Hydromatic setup, not sure why, but that could also be why it takes a while to get all of the air out..
JT
JT
Usually though, if they were bulging that much, I'd think they be collapsing just as badly, which would lock up the brakes..
amoosenamedhank: What was leaking exactly on the resevoir?? Was it the res. itself, or the seal?? I'd think you'd be able to see bubbles in the MC, unless the fluid was really dark..
JT
JT
