replacing coolant question..
i was going to replace my coolant until i found out that my fill plug is seized or frozen on the damn crossover pipe. i guess only cobras have this problem because the radiator is lower than the engines highest point, so you have to fill it up at the filler hole and not in the resovoir. well actually idk how the GTs set up is. so yeah, i wanted to know if i can jsut raise the front of the car and just fill from the resovior because idk know how to take the filler plug off. and i can imagine doing more damage than id want to if i even tried to take it off. so do you think i can do that? has anyone tried? i wouldnt want to end up with a whole bunch of bubbles inside the passages because a crack is what im afraid of!
I've never put coolant/water in anything but the overflow reservoir when refilling on any car. I guess I don't get why you think you can't put coolant in your overflow reservoir...Or I guess I don't understand why you think you'd need to raise the car while filling
I have this one
http://buy1.snapon.com/catalog/item....re&dir=catalog
Anyway, lifting the front of the vehicle might be a solution, but I doubt it with our cars. Find someone who can weld, and weld a nut on top of the fill plug on the cross-over, then work it out with some heat and a big ratchet.
Hes talkin about the coolant cross-over on Cobra motors. There is a small fill plug that seizes in and makes filling and bleeding the system a nightmare.
And you must not know much about burping a coolant system or much about how tempermental 4V motors are to get the air out. I had the same problem with my old Cobra. I, however, bought a vacuum filler that pulls vacuum on the system, then uses its own vacuum to jam coolant in without air.
I have this one
I have this one
You should still be able to fill it up with the resivour and warm the car up with the cap off and let it bubble out. That's how I do mine, although I fill it up at the thermostat first, but you cobra guys cant do that either so idk.
wow $230.00 for that piece? thats a whole lot of money to be investing on, i dont even replace my coolant often. thanks though! anyway yeah, some of you probably dont know how the 98 cobra motors look. the whole system is pressurized so its not like the traditional radiator, overflow tank set up. and also the highest point of the engine sits higher than the radiator so if you drain it everything will come out buh how do you get liquid to defy gravity and go up to the highest point of the engine? well back to the subject, so is there any other methods in doing this besides the welding? like WHITEFOX said, its a nightmare. i wouldnt want to risk any damage..
