QA1 K member Differences????
There is this one.....
http://www.uprproducts.com/shopping/shopexd.asp?id=1465
And then, There is This one...
http://www.hawaiiracing.com/?page=sh...b0ee5f1779d61&
Just curious the bottom one I can get for $90
They both have different hole patterns where the motor mounts go, but both for 96-04. Is the second one just a Phased out Qa1???
Thanks for the Reply!
Chrome-Moly is lighter and stronger but it has it's draw backs. Chrome-moly is more brittle then mild steel and some people have reported having issues with them cracking when used on a street car. Most people will recommend the mild steel K member for street use.
Thanks... With a Qa1 (the mild steel Version Pic 2) can i use any A Arms? ( MMR, MM, Qa1??) Same with the Coil Over kit? When i drop my motor im going to put this in along with the coil over setup.
Thanks again!
Thanks again!
I'm not sure of the interchangeability of the A arms. I used the QA1 A arms, they were cheap and worked well.... I would just get them if you're getting a QA1 K member.
Personally I'm not a fan of the QA1 coil over kit because you have to use their special threaded strut with their kit. Doesn't give you much for choices. I went with a D&D coilover kit.
mungodrums
Suspension
09-24-2015 10:12 PM
