Everything needed for safe nitrous
Well the tax refund was about $1000 dollars more than expected so im buying nitrous for my car. What do I need to buy to have a safe and reliable nitrous system.
I think this is where im getting the system but I need to know what else I need to buy
http://www.dynotunenitrous.com/store...?idproduct=252
1. with 1000 to work with, id get a differant kit
look into the nx plate kit, or i personally use NOS... and zex.
id get...
nx or nos kit-550
purge-100
heater-100
fpss-cheap
msd digital window switch-100
zex tps switch-60
spend the other 100 on a tune, assuming you have a tuner, if you dont, save it, spray 100 on good gas, when you have the <$400, get it tuned.
fwiw i sprayed a 100 shot on a stock tune with 93oct gas for quite a while, and ran the times in my sig tons of times.
id get...
nx or nos kit-550
purge-100
heater-100
fpss-cheap
zex tps switch-60
My old NX plate kit I had back in the day didnt and I didnt see a guage in the kit above, so I thought I would throw it in. If your new to nitrous then one thing to keep in mind is the pressure, it has to be maintained between 900-1000 psi. If the pressure is low, your going to run rich, and the opposite with to high you will run lean. This is one of the most important factors for nitrous to be safe. Unless you like to make taco salad out of engine parts that is...
