Power steering pump
Power steering pump
I'm trying to get mine off. I got three bolts that look like they hold it on. Is there something else that holds it on? I don't have to take the pulley off, do I? I don't see anything else that could be holding it on, but it's not bugding.
Any advice? That and the crank pulley are the only things in the way to getting my timing cover off.
Hmm. Wow. I really shouldn't be working in my glasses, then, lol. My contacts are a hell of a lot stronger. I'll go look for that last bolt later. It felt like something else was holding it on, but I couldn't find it for the life of me, lol.
And I figured I'd need a puller. AutoZone should probably rent them, no?
yep i rented a puller from advanced auto. its possible to take that bolt off without taking off the line if you dont want to deal with bleeding the system and having fluid drip everywhere. just use a wrench instead of socket and the bolt will just stay with the pump.
It just sucks cause for some rediculous unknown reason, I do not have a 10mm wrench ANYWHERE in my house. It really sucks cause I was motoring right through everything, and then I hit a ****in' brick wall cause I don't have a 10mm wrench at home. **** me, lol.
uberstang1
09-20-2015 06:42 PM
